Ansys Learning Forum Forums Discuss Simulation Photonics How to calculate modal overlap coefficient during the second harmonic generation Reply To: How to calculate modal overlap coefficient during the second harmonic generation
211123090062
Hello, I'm sorry for replying so late. The following is a screenshot of the code line that caused the error:
Where E11=getresult("mode1","E"),E1=sqrt((abs(Ex1))^2+(abs(Ex1))^2+(abs(Ex1))^2);
I entered the code based on the overlap coefficient calculation formula,and used the "size" you provided to check the size, but I don't know how to adjust it to avoid errors. If you could tell me the method, I would greatly appreciate it!
