Ansys Learning Forum › Forums › Discuss Simulation › Fluids › VOF Free Surface Deformation › Reply To: VOF Free Surface Deformation
May 31, 2024 at 3:44 pm
Reverse flow isn't an error, it's a warning. Given the flow is probably more-or-less aligned with the boundary there's a good chance the mass of back flow is fairly low: have a look at the velocity vector plots. Also, have a look at the backflow options in the panel (hint, preventing backflow needs to be used with caution, so don't just look at that).Â
