Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › [Mechanical APDL] Reducing element load balance ratio in a model with contacts › Reply To: [Mechanical APDL] Reducing element load balance ratio in a model with contacts
May 31, 2024 at 8:38 am
conta174 should be supported for contact splitting, conta175 is not, as mentioned in the last section. Please try using contact splitting techniques and see if it helps improve the load balance ratio and performance.
-Aniket
