Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Rocky 2024R1 shows error “Cannot find path to Solver license” Reply To: Ansys Rocky 2024R1 shows error “Cannot find path to Solver license”
Yidong Xia
Raj, thank you for your reply. Please see my response below per your instructions.
Also set the environment variable ANSYSLMD_LICENSE_FILE = portno.@servername in your system environment settings and try to relaunch the application.
I assume "portno." is "port number". What does this port number can be?
In your start menu type %temp%> .ansys> over there will be a file named "*rocky", please share screenshot of that file.
The screenshot is below. I am also copying and pasting the content in the file "licdebug.INL466957.ROCKY.241" for your inspection. I do see error related messages. Hope that would give you clue how to fix the issue.
2024/05/28 15:54:21    INFO                Starting Licensing Client Proxy server.
2024/05/28 15:54:21    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 18268.28458 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.18268.28458.log
2024/05/28 15:54:21    INFO                Started ANSYSLI server.
2024/05/28 15:54:22    CLIENT_CONNECT        18268:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 15:54:22    NEW_CONNECTION      Connected to Licensing Client Proxy server: 53968@127.0.0.1.
2024/05/28 15:54:22    CHECKOUT            rocky_preppost                  24.1 (2023.0823)             1/1/1/1   18268:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 15:55:03    CHECKIN             rocky_preppost                  24.1 (2023.0823)             1/0/0/1   18268:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 15:55:11    INFO                Starting Licensing Client Proxy server.
2024/05/28 15:55:11    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log
2024/05/28 15:55:11    INFO                Started ANSYSLI server.
2024/05/28 15:55:12    CLIENT_CONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 15:55:12    NEW_CONNECTION      Connected to Licensing Client Proxy server: 54019@127.0.0.1.
2024/05/28 15:55:12    CHECKOUT            rocky_preppost                  24.1 (2023.0823)             1/1/1/1   6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 15:58:50    ERROR               Unable to connect to ansyscl on port 54019 as ansyscl is not currently running.
2024/05/28 15:58:50    INFO                Starting Licensing Client Proxy server.
2024/05/28 15:58:50    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -aclport 54019 -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log
2024/05/28 15:58:50    INFO                Started ANSYSLI server.
2024/05/28 15:59:05    CONNECT_ERROR       rocky_solver                                                           3764:ROCKY:XIAY@INL466957.inel.gov:winx64
ANSYSLI exited or could not read server port ansyscl.INL466957.6764.14395.
Please refer C:\Users\XIAY\AppData\Local\Temp\1\\.ansys\ansyscl.INL466957.6764.14395.log for more information.
2024/05/28 17:14:13    HEARTBEAT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
System error: 10054 "An existing connection was forcibly closed by the remote host.
2024/05/28 17:14:13    ERROR        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
License Handler Disconnected: System error: 10054 "An existing connection was forcibly closed by the remote host.
2024/05/28 17:14:14    SERVER_DISCONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
License server 54019@INL466957.inel.gov has disconnected unexpectedly.
    ANSYSLI_SERVERS: 2325@INL466957
    FLEXlm Servers: 1055@INL466957
2024/05/28 17:15:11    INFO                Starting Licensing Client Proxy server.
2024/05/28 17:15:11    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log
2024/05/28 17:15:11    INFO                Started ANSYSLI server.
2024/05/28 17:15:12    CLIENT_CONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 17:15:12    NEW_CONNECTION      Connected to Licensing Client Proxy server: 62034@127.0.0.1.
2024/05/28 17:15:12    RECONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/28 17:15:12    INFO        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
License server connection restored.
Connected to server 62034@INL466957.inel.gov.
2024/05/28 17:15:12    RECHECKOUT          rocky_preppost                  24.1 (2023.0823)             1/1/1/1   6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:06    HEARTBEAT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:06    ERROR        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:07    SERVER_DISCONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
License server 62034@INL466957.inel.gov has disconnected unexpectedly.
2024/05/29 15:41:11    INFO                Starting Licensing Client Proxy server.
2024/05/29 15:41:11    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 6764.14395 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.6764.14395.log
2024/05/29 15:41:12    INFO                Started ANSYSLI server.
2024/05/29 15:41:13    CLIENT_CONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:13    NEW_CONNECTION      Connected to Licensing Client Proxy server: 62333@127.0.0.1.
2024/05/29 15:41:13    RECONNECT        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:13    INFO        6764:ROCKY:XIAY@INL466957.inel.gov:winx64
Connected to server 62333@INL466957.inel.gov.
2024/05/29 15:41:13    RECHECKOUT          rocky_preppost                  24.1 (2023.0823)             1/1/1/1   6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:41:33    CHECKIN             rocky_preppost                  24.1 (2023.0823)             1/0/0/1   6764:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:51:17    INFO                Starting Licensing Client Proxy server.
2024/05/29 15:51:17    INFO                C:\Program Files\ANSYS Inc\v241\licensingclient\winx64\ansyscl.exe -acl 19928.41057 -nodaemon -log C:\Users\XIAY\AppData\Local\Temp\1\.ansys\ansyscl.INL466957.19928.41057.log
2024/05/29 15:51:17    INFO                Started ANSYSLI server.
2024/05/29 15:51:18    CLIENT_CONNECT        19928:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:51:18    NEW_CONNECTION      Connected to Licensing Client Proxy server: 65240@127.0.0.1.
2024/05/29 15:51:18    CHECKOUT            rocky_preppost                  24.1 (2023.0823)             1/1/1/1   19928:ROCKY:XIAY@INL466957.inel.gov:winx64
2024/05/29 15:54:15    CHECKIN             rocky_preppost                  24.1 (2023.0823)             1/0/0/1   19928:ROCKY:XIAY@INL466957.inel.gov:winx64
