Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Electric/Magnetic field distribution (Re-Im-Abs-Abs^2) on Lumerical RCWA › Reply To: Electric/Magnetic field distribution (Re-Im-Abs-Abs^2) on Lumerical RCWA
May 29, 2024 at 3:11 pm
Hi Giovanni,
You may use an RCWA field monitor to record the field distribution. You should see it in the drop-down options in "Monitors". You may record the field in 3D as well. I haven't really used it a lot. But I have heard feedback from my colleagues that the RCWA monitors reduce the simulation speed significantly. So, I would recommend using it when it is essential.
Amrita
