Ansys Learning Forum Forums Discuss Simulation Fluids Room simulation with enclosure (Internal & external flow) Reply To: Room simulation with enclosure (Internal & external flow)
Sunil Lilhare
Hello, it is quite unclear from the given information whether how exactly you are trying to model the single room. However, if you are defining one inlet, that too on one of the sides of enclosure, then I would recommend you to create single solid room, then create enclosure around it, substract the solid room from enclosure to get only single fluid zone and then do the simulation after creating a good mesh.Â
