May 23, 2024 at 2:41 pm
Mehmet D.
"Have a play, I tend to finish up with both options selected and then don't set a wave type. I no longer have 2021 installed and from memory the panel has changed compared to 2024."Â
I'm not sure I understand this part. Did you try solving the same problem in the 2024 version and succeed? If so, how did you achieve it? I believe if you succeeded, I should be able to as well. While there may be improvements between the 2021 and 2024 versions of ANSYS, the ability to obtain wave elevation shouldn't be version-dependent.
In my case, this time my U∞ is 2.193 m/s, h/c = 1 and the leading edge of the foil is located at 0.
