Ansys Learning Forum Forums Discuss Simulation Fluids Issue in Computing Fluxes through New Created Surfaces — Fluent 2023R2 Reply To: Issue in Computing Fluxes through New Created Surfaces — Fluent 2023R2
nicolo.cappello
Dear Rob, no problem, thank you for your support.
So if I've understood it correctly you suggest defining a custom vector corresponding to the velocity vector and then use Surface Report -> Custom Vector Flux ?
Am I misunderstanding your advice?
Thank you!
