Ansys Learning Forum Forums Discuss Simulation 3D Design airflow valve problem with solids Reply To: airflow valve problem with solids
Devendra Badgujar
Hi Kasper,
We cannot donwload the files from here. I would recommend try increasing fidelity to see if that helps.
If you can share the details of model tree and physics tree that will help here. Also, how does the flow exists from the valve?
Devendra
