Ansys Learning Forum Forums Discuss Simulation 3D Design Chamfer with Variable Radius Round Corner and Straight transition? Reply To: Chamfer with Variable Radius Round Corner and Straight transition?
Gerry Brown
Seems i almost figure how make it. If i click to inner corner magenta dot and change value from 100% to 0%, variable radius lines became straight. Next i can drag inner corner arrow near that dot, press Space key and and enter value 0.
But problem partially remains because it is impossible simply enter radius value of round corner that will match to exact chamfer size. So i must guess it. For example if Chamfer size is 2mm, and if i enter round corner 2mm raduis – it feels too small. For 2mm Chamfer i need to enter corner radius something like 4.2mm.
