Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Information about to put some inputs in ANSYS workbench. › Reply To: Information about to put some inputs in ANSYS workbench.
May 17, 2024 at 1:32 pm
You can use parameter set in Workbench. In Mechanical you specify input / output parameters. Then in WB Project page you open the parameter set and add design points. Please take a look at below in the documentation.
Setting up parameters in Mechanical: Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_Parameters_Specifying.html
working with parameters: Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb2_help/wb2h_parameters.html
