Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error when trying to compile UDF › Reply To: Error when trying to compile UDF
May 17, 2024 at 10:39 am
Source terms will add/remove material or stuff from cells. You set the rates so you'd need contact area etc from the solver to get the phase change and would have to manually resolve everything. Â DEFINE_MASS_TRANSFER should handle most/all of the mass & energy for you, Â https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_udf/flu_udf_MultiphaseDEFINE.html%23flu_udf_sec_define_mass_transfer
