Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problems with a simple tire model › Reply To: Problems with a simple tire model
May 17, 2024 at 10:36 am
If the end result is to get both fingers on the cylindrical surface, and you don't need to monitor the insertion force, I suggest you reduce the lead-in angle on the grey body. That may help expand the elastomer without the solution failing to converge. You may need to move the grey body more than 5 mm to get the elastomer onto the cylindrical surface.
