Ansys Learning Forum Forums Discuss Simulation 3D Design Select all objects in Layer Reply To: Select all objects in Layer
David Hills
An Ansys engineer has helped me to close this issue. The resulting code is:
def fillSelected(layer_curves):
    #fill the curves in the layer. this creates a new surf body
    selection = Selection.Create(layer_curves)
    secondarySelection = Selection.Empty()
    options = FillOptions()
    result = Fill.Execute(selection, secondarySelection, options, FillMode.ThreeD)
allCurves = GetRootPart().GetDescendants[IDesignCurve]()
for layer in Layers.GetAllLayers():
    layer_curves=[i for i in allCurves if i.Layer==layer]
    if not len(layer_curves)==0:
        Layers.Activate(layer.GetName())
