Vincent Letourneau
@Guilin, I'm unfortunately quite unfamiliar with the rest of Lumerical. Could you give me instructions to run my simulation without the python api? The code launching the simulation is copied below.
@Lito, I am connecting to the cluster with ssh + X11 forwarding.
from lumopt.utilities.simulation import Simulation
from lumopt.figures_of_merit.modematch import ModeMatch
sim = Simulation('.', False, False)
fom = ModeMatch(monitor_name = 'fom', mode_number = 'Fundamental TE mode', direction = 'Forward', norm_p = 2)
sim.fdtd.load("./files/forward_0.fsp")
size_x = 2000
delta_x = 20
size_y = 1800
delta_y = 20
x_points = int(size_x / delta_x) + 1
y_points = int(size_y / delta_y) + 1
x_pos = np.linspace(-size_x / 2, size_x / 2, x_points) * 1e-9
y_pos = np.linspace(0, size_y, y_points) * 1e-9
sim.fdtd.switchtolayout()
sim.fdtd.putv('x_geo',x_pos)
sim.fdtd.putv('y_geo',y_pos)
\sim.fdtd.putv('z_geo',np.array([0-110e-9,0+110e-9]))
sim.fdtd.putv('eps_geo',eps_for_sim)
script=('select("import");'
'delete;'
'addimport;'
'temp=zeros(length(x_geo),length(y_geo),2);'
'temp(:,:,1)=eps_geo;'
'temp(:,:,2)=eps_geo;'
'importnk2(sqrt(temp),x_geo,y_geo,z_geo);')
sim.fdtd.eval(script)
fdtd.run()
print(fom.get_fom(sim))
