May 15, 2024 at 12:32 pm
peteroznewman
Bbp_participant
Hello Sami,
I looked at your model and found it is very well done. It has a good mesh and all the boundary conditions are correct.
I used an online calculator that uses Lame's equation to calculate the Interference pressure for the values in your model and it came up with 81.5 MPa which is close to the Ansys result of 83 MPa.
Peter
