Guilin Sun
" in the range L=1.6~1.8um" do you mean the location of the monitor? or wavelength?
Since one can install two versions, I would suggest to reinstall the older version (uninstall the newest version first) and then reinstall the newest version, then compare the results and see what has been changed. From the release notes that you can search online, I did not find any mention for FDTD meshing, port/monitor. Maybe material fitting changed? it is hard to diagnose with only one version.Â
