Simone LuX
Contact: Bonded,
Formulation: MPC
select all DOFs if you want to connect also the rotations so the moment.
You can check the moment is properly passing trough the elements, by loocking at the result:
ENMOVECTORS (unaveraged) at the connection. (Must be non-zero)
