Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unrealistic result in Non-linear FEA › Reply To: Unrealistic result in Non-linear FEA
May 13, 2024 at 1:21 pm
The stress value seem to be low (~ 0.017Pa) and it should not be the issue of element distortion. Can you check the results in true scale? Also, if you check the solver output did you see any element distortion errors?
Ashish Khemka
