Ansys Learning Forum Forums Discuss Simulation Electronics Q3D parametric sweep field calculator Reply To: Q3D parametric sweep field calculator
Praneeth
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please go through the following response which is inline with your questions
  • Yes, It is possible to apply parametric sweep solutions inside fields calculator. For this, you should have enabled "save fields and mesh" option in the parametric analysis. For more details about this feature, please go through "setting options" section of the Q3D help document.
  • Yes, there is a scripting window for all design types in AEDT. Please select the automation tab and you will see the available options.
In the post, it is mentioned that you have calculated for one variation. Please enable "record script" and do the calculations for automating the process. For more details, please go through the scripting guide.
Best regards,
Praneeth.
