Ansys Learning Forum Forums Discuss Simulation Preprocessing SpaceClaim: Utilizing ‘Simplify’ to Locate and Eliminate Errors in CAD Model Reply To: SpaceClaim: Utilizing ‘Simplify’ to Locate and Eliminate Errors in CAD Model
peteroznewman
The method I use to delete engraved letters is to use the Select tool on the Design tab.  Simply drag a box over the set of letters, making sure to not select an entire face of the body, then with the mouse on the graphic window, simply hit the delete key on the keyboard.
