Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical version change results in output discrepancy › Reply To: Lumerical version change results in output discrepancy
May 9, 2024 at 7:44 pm
Hi Guilin,
Thank you so much for your reply!
It's better for us to share the original fps files to you via email. Otherwise, what we described above is meaningless.Â
may I know what does "the initial E field" mean here? "The initial E field" means the initial Input of the source in FDTD model.
did you chage the source amplitude? No.
or any other change to the simulation files? No.
the phase change is a 2pi jump, or slight change in magnitude? Slightly (sub-rad) phase change.
