Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Unusual liquid velocity and bubble size distribution by using PBM › Reply To: Unusual liquid velocity and bubble size distribution by using PBM
May 9, 2024 at 12:20 pm
Thanks for your replying.I will try Custom Field Function.
And is there a solution to the bubble bin fraction in the head space?Â
I write an udf to make the aggregation rate only below the liquid surface by limiting the height, but it didn't help.There are still bubble bin fraction above the liquid surface.
I can give more information if you need.
