Ansys Learning Forum Forums Discuss Simulation General Mechanical Air heat insolation Reply To: Air heat insolation
Ashish Khemka
In a steady state thermal analysis we generally define convection b.c. to simlate the fluid surrounding the structure. Do you have the film coefficient and ambient temperature for static air (ideally film coefficient should be zero for static air)? If you do not define any b.c. then it will be considered an adiabatic surface.
Ashish Khemka
