Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Steady-State Thermal in case of Layered Sections › Reply To: Steady-State Thermal in case of Layered Sections
May 8, 2024 at 12:32 pm
Even though the layers are thin you can still use solid elements. If a well-shaped brick mesh is used the aspect ratio can be large. In the end, layers of thin solids are about the same as a layered shell.
