Ansys Learning Forum Forums Discuss Simulation Fluids Pressure drop through a hole in a pipe Reply To: Pressure drop through a hole in a pipe
You can check the options in the contour panel and View tab but some of the legend set up is hard coded. It's also changed several times over the last few releases as Fluent's graphics have been upgraded.Â
