Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Keep a mesh consistent between analysis systems › Reply To: Keep a mesh consistent between analysis systems
May 8, 2024 at 6:20 am
Aniket
if you simply drag and drop transient structural system on existing static structural one, it should take exact same mesh used in the static one. Does that not work?
Also, even if they are separate systems, mesh order matters if you are using shared topology. so try to mesh bodies one by one in same order as you did in earlier method.
-Aniket
