Ansys Learning Forum Forums Discuss Simulation LS Dyna applying gravity and earthquake in z direction Reply To: applying gravity and earthquake in z direction
Maryam Tabbakhh
I did that as well but the problem is that the speciment moves and doesn't reach the equalibrium like when there is a real zero boundary condition. I applied the same loading in y direction (the boundary was fixed in z direction during the analysis) so it reaches equilibrium and then I applied the acceleration in horizontal direction. Than'ts why the first solution doesn't work. But by adding the spc birth/death the problem of gravity initialization is solved but it gets unstable after that.Â
