Ansys Learning Forum Forums Discuss Simulation Fluids Discontinuity at Interface between Rotating and Stationary Domain Reply To: Discontinuity at Interface between Rotating and Stationary Domain
The holes may just be a contour plotting issue. The mesh looks OK, albeit the jump in cell size isn't ideal. Can you plot the Q-criterion on planes with node values off so we can see another field?  The fact that the model has the stability warnings isn't good, so I'd be wary of trusting the results.Â
