Praneeth
Thanks for your reply. Your patience is much appreciated.
Please note that I suggested checking your hardware as you reported the application was crashing while wrapping the objects. I tried the scenario you mentioned and the application was working as expected. Based on your latest information, I suggest you try the same thing on any other hardware to see if the issue is with the application or the hardware.
Hope this helps.
Best regards,
Praneeth.
