Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDS Residence Time › Reply To: UDS Residence Time
May 3, 2024 at 4:42 pm
Thank you so much.
So instead of using mass source, I will be using scalar sourcem right?
If so, I think we may need to change step 5 in the pdf file mentioned above.Â
5. Under Source Terms, enable (Mass) sources and specify the fluid density (If the density varies by location, you can use a UDF).
