Ansys Learning Forum Forums Discuss Simulation Fluids Measurement of Adhesion forces Reply To: Measurement of Adhesion forces
There aren't any built in models for how sticky a wall is, the base boundary conditions are covered here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_ug/flu_ug_sec_discrete_bc.html
Depending on what you're trying to do Ansys Rocky has adhesion models, but you'd need to set the adhesion forces and then use the solver to work out whether particles detach for the flow conditions that you provide from Fluent via the coupling functions.Â
