Ansys Learning Forum Forums Installation and Licensing Ansys Products can’t open the deafult TD file anymore Reply To: can’t open the deafult TD file anymore
Ian Pond
With the Ansys 2024r1 license client, can you verify that you see Ansys Thermal Desktop licenses available in the "View Flexnet Licenses" list?
There is a chance the issue is related to an Autocad Workbench Plugin, if you look in your start menu, you can use the following,
to uninstall the Autocad Plugin.
