Ansys Learning Forum Forums Installation and Licensing Ansys Products Ls-Dyna beam frictional contact with solid Reply To: Ls-Dyna beam frictional contact with solid
Puneeth Bagaria
Hello Fady,
There are two aspects of dealing with beam and solid element contacts.
1) Node of beams contacting against the surface of solid elements: You can use any node-segment contact for this purpose. *CONTACT_AUTOMATIC_NODES_TO_SURFACE or *CONTACT_AUTOMATIC_SINGLE_SURFACE for example.
2) Beam vs edges of the solid elements: An edge to egde contact is required here. This can be enabled by using SOFT=2 (DEPTH=5) in *CONTACT or by using a seperate *CONTACT_AUTOMATIC_GENERAL defined only on the edges + beam elements.
Please refer to the below resources for more information:
Contact Modeling in LS-DYNA — Welcome to the LS-DYNA support site
Contact between Beam and Shell Elements — Welcome to the LS-DYNA support site
Regarding the section formulations available for beam elements:  Please refer to *SECTION_SHELL of LS-DYNA keyword manual vol-1.
Regards
Puneeth
