randyk
Hi Saeid,
Make sure each involved computer can resolve the IP of the other involved computers.
ex:  'ping saeid_surface' from desktop-njrebou   should respond successfully.
Your screenshot shows 2 solver engines running.
That is one limitation with AnsoftRSMService, it has no scheduling capabilities and all jobs are run simultaniously.
This could result in resource contention / solver failures.
Consider a 3rd party scheduler to avoid this situation.
Another item with Ansoftrsmservice, the solvers will run as the owner of the RSM service
-- Ansoftrsmservice is usually run as 'Local Service' user
-- To run solvers as a specified user, you would set the user/pass/domain in:  AEDT: Tools->Options->General Options->Remote Analysis (tab)
