Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › 3D Tire Modeling using Ansys Mechanical Static Structural – Help !! › Reply To: 3D Tire Modeling using Ansys Mechanical Static Structural – Help !!
April 25, 2024 at 9:05 pm
Thanks for your help, I set the size of the elements to 2mm because if I used a higher value the program wouldn't create a continuous mesh.Â
I also had problems with the contacts, because of possible penetrations, should I specify each of the contacts between the different materials that make up the tire as "Bonded" ?
What should i change in the u-P formulation ? i don´t know wich type of elements i have ... like 182 181 ectÂ
