Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Run IronScript from slurm › Reply To: Run IronScript from slurm
Hi RandykÂ
Thank you for your response . Below is my slurm file can you please assist in telling me where exactly is appropriate for the export line
I have highlighted the 3 places i was thinking ... also please find my ironscript attached . Appreciatre you assistance
#!/bin/bash
# SLURM job script to run Ansys in parallel on a single node using 4 CPUs
#SBATCH --job-name   SAR_gpu_script
#SBATCH --time     60:00:00     # Wall time
#SBATCH -p gtx1080
#SBATCH --gres=gpu:1
#SBATCH --ntasks=40Â Â Â Â Â Â Â Â Â Â Â Â # Number of processes
#SBATCH --nodes=1
#SBATCH --mail-user=krp1n21@soton.ac.uk
#SBATCH --mail-type=ALLÂ
module load ansysewb/23.2
OPT_FILE=batch_options.txt
echo "\$begin 'Config' " > ${OPT_FILE}
#echo "'HFSS/SolveAdaptiveOnly'=O" >>Â ${OPT_FILE}
#echo '"HFSS 3D Layout Design/MPIVendor"="Intel"' >> $OPT_FILE
#echo '"tempdirectory"="$SCRATCH"' >> $OPT_FILE
#echo '"Desktop/ProjectDirectory"="$SCRATCH"' >> $OPT_FILE
#echo "'ANSYSEM_FEATURE_SF6694_NON_GRAPHICAL_COMMAND_EXECUTION_ENABLE'=1" >>Â $OPT_FILEÂ
#echo '"Send Config"' >> $OPT_FILE
machines=$(srun bash -c 'hostname' | sort | uniq | awk -v ntasks="$SLURM_NTASKS_PER_NODE" '{print $1 ":" ntasks}' | paste -s -d ',')
#machines=$(srun bash -c 'hostname -s' | sort | uniq | awk '{print $1 ":" 40}' | paste -s -d ':')
echo $machines
export ANSYSEM_FEATURE_SF6694_NON_GRAPHICAL_COMMAND_EXECUTION_ENABLE=1
# Run ansys commands in file plate in batch mode
#( the -m & -db flags increase the total amount of memory usable by ansys)
ansysedt -features=beta -ng -runscriptandexit SAR_script.py -batchsolve -distributed -machinelist list=$machines -monitor -batchoptions ${OPT_FILE} "ANSYSEM_FEATURE_SF6694_NON_GRAPHICAL_COMMAND_EXECUTION_ENABLE=1" "EnbleGPU=1" SAR_simulationi.aedt
