Ansys Learning Forum Forums Discuss Simulation 3D Design Results not displayed in Discovery Refine Reply To: Results not displayed in Discovery Refine
THO
Hello Devendra,
I tried it on more models and face this issue with every models as well. It seems that the limit is ~1.5million mesh elements and ~2.5million mesh nodes, above these element/node numbers the results cant be displayed. Mesh is generated and displayed in every case. I tested it on the built-in sample model "Bracket_static_stress", see below. If if change min. face size to 0.06mm and max sizes to 0.6mm, results can be displayed and the model works well.
You can see the mesh settings on the top and the mesh element/node numbers on the bottom right corner. Can you test these settings on this sample model, please? Thank you in advance.
