Ansys Learning Forum Forums Discuss Simulation General Mechanical Damping in Response Spectrum Analysis Reply To: Damping in Response Spectrum Analysis
Chandra Sekaran
You will need to use APDL commands to input multiple curves with different damping ratios and to specify the damping ratio for each mode
The spec I am using provides SRS curves for many damping values. How would I choose which to use?
You should input all the spectral curves along with their damping ratio values using SV,damp,sv1,sv2,...  Refer to FREQ and SV commands to understand the format.
I am performing a response spectrum analysis on a system with many modes, each with it's own damping ratio.
You can use MDAMP command to input the damping of each natural frequency
