Ansys Learning Forum Forums Discuss Simulation Fluids Changing the geometry in existing case Reply To: Changing the geometry in existing case
If you're monitoring on the holes then gaining or losing surfaces may cause problems with the reports. Otherwise the solver should read in a new mesh without too many issues. Look in the /file TUI menu for settings file options.Â
