Ansys Learning Forum Forums Discuss Simulation Electronics Mesh Size in Ansys Maxwell 2D Simulations Reply To: Mesh Size in Ansys Maxwell 2D Simulations
HDLI
Hello Dharani,
      To determine accuracy of results, the key is to decrease element size until the results are similar. Thus, changing mesh size is necessary to check if the results are correct or not. Motion.torque is calculated by virtual work method and Maxwell stress tensor force is based on the B field values of air gap, that may be more sensitive than the virtual work method.
HDLI  Â
