Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two way FSI › Reply To: Two way FSI
April 18, 2024 at 7:16 am
it is recommended that you build up to the final two-way analysis incrementally, progressively adding complexity with each step. Check if your participant solutions works fine with representative loads. Look at the transcript files for errors if any.
Please refer Building a Coupled FSI Analysis from Decoupled Participant Problems (ansys.com).
