sahua1
Hi George,
Thank you for the response.
We are running locally on the Linux server.
Please find below the log details. (I am not able to attach the file so I am pasting the log here)
Event log opened 4/16/2024 12:18:20 PM EST
Product version: 2023 R2
Build version: 23.2.0.0
{4/16/2024 12:18:36 PM} [ProjectReplaced:Project] A new project has been created.
{4/16/2024 12:18:55 PM} [ProjectReplaced:Project] The project has been opened from /home/pateh123/Harsh simulation/Server analysis/server_run.wbpj.
{4/16/2024 12:19:37 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.
{4/16/2024 12:19:37 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
{4/16/2024 12:19:40 PM} [UpdateMessage:Project] Update of the Solution component in Seperate key with  press fit_new_maetrial failed: Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
  at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in :0
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in :0
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in :0
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in :0
--- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="5456da2eb0ae4a05a4891d7a134bb697", DesignPointUpdateQueue=None, MaxNumberOfCores=0))
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in :0
  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in :0
  at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
{4/16/2024 12:19:41 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Seperate key with  press fit_new_maetrial.  Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Seperate key with  press fit_new_maetrial.  Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
  at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in :0
--- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Seperate key with  press fit_new_maetrial.  Error updating cell Solution in system Seperate key with  press fit_new_maetrial.
CommandName: UpdateSystem(System="/Schematic/System:SYS", AllDependencies=True)
  at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in :0
  at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
  at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in :0
  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in :0
  at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0
  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in :0
{4/16/2024 12:22:21 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.
{4/16/2024 12:22:21 PM} [BatchModeApplicationWarning:MechanicalEditor] Not enough constraints appear to be applied to prevent rigid body motion.  This may lead to solution warnings or errors.  Check results carefully.
{4/16/2024 12:22:21 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
{4/16/2024 12:22:29 PM} [UpdateMessage:Project] Update of the Solution component in Full stack failed: Error updating cell Solution in system Full stack.
Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Full stack.
--- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Full stack.
CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="eeccc522205f4dca87e2b4f21c9f9dde", DesignPointUpdateQueue=None, MaxNumberOfCores=0))
{4/16/2024 12:22:29 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Full stack.  Error updating cell Solution in system Full stack.
--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Full stack.  Error updating cell Solution in system Full stack.
--- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Full stack.  Error updating cell Solution in system Full stack.
CommandName: UpdateSystem(System="/Schematic/System:SYS 2", AllDependencies=True)
{4/16/2024 12:22:52 PM} [ProjectSaved:Project] The current project has been saved: /home/pateh123/Harsh simulation/Server analysis/server_run.wbpj.
