Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Divergence detected during single particle deposition analysis › Reply To: Divergence detected during single particle deposition analysis
April 11, 2024 at 11:22 pm
I agree
What can I do in that case? I consider that I have the Overset mesh set correctly.
I also usually activate options for the interaction between the background and overset. Such as the donor priority method that I told you about, render receptor cells, verbosity, and intersect-all.
I could share the .msh files with you, is there no problem with that?
