Guilin Sun
This is a very interesting discovery!
I did not find the reference paper for stiching method. But I guess it may not conisder the off-axis effect: it may assume that the propagation has the same axis as the incident or the desired diffraciton order.
I guess this is a theoretical problem. You have verified with direct simulation so such stiching method might need to be improved.
