Omar Elgack
Hello Ashish,
Thank you for your support. I just have a simple question here. I noticed that the distance between the points is always 0.8 mm along the scanning direction for a slicing stripe width equals to the part dimension. You can tell this from the x coordinates of the points in the picture. This is the case for whatever value of sensor radius I use, which does not make sense. I would like to know if it is possible to reduce this distance and how, please?
Omar
