Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Fluent Calm Water Conditions for decay test › Reply To: Fluent Calm Water Conditions for decay test
April 5, 2024 at 2:22 pm
Zero flow is fine. Note, the D in CFD is Dynamics so you may find converge (residuals) to be relatively poor - also review what the residuals represent.Â
Have a look at the surface reports for mesh; you may not have an easy angle report but min/max may be sufficient? Unless the UDF for 6DOF can return something?Â
