April 4, 2024 at 6:12 pm
Ashish Patil
I had selected machine type as pmdc motor but under analysis setup the operation type is not changing. It is by default set to motor and not changing to generator and also the on the extreme right of the analysis setup the read only box is checked which i am not able to de-select.
Tomorrow I will show you the setup1 and machine type.
Regards
