Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS Dyna – can’t reach license server › Reply To: LS Dyna – can’t reach license server
  ___________________________________________________
   | Livermore Software Technology Corporation |
   | 7374 Las Positas Road |
   | Livermore, CA 94551 |
   | Tel: (925) 449-2500 Fax: (925) 449-2507 |
   | www.lstc.com |
   |_________________________________________________|
   | LS-DYNA, A Program for Nonlinear Dynamic |
   | Analysis of Structures in Three Dimensions |
   | Version : smp s R8.1.0 Date: 02/24/2016 |
   | Revision: 105896 Time: 14:28:04 |
   | Features enabled in this version: |
   | Shared Memory Parallel |
   | FFTW (multi-dimensional FFTW Library) |
   | Interactive Graphics |
   | ANSYS Database format |
   | ANSYS License (ANSYS145) |
   | Licensed to: |
   | Platform : WINDOWS X64 |
   | OS Level : Windows 7/8/10 & Server 2008/2010 |
   | Compiler : Intel Fortran XE 2013 MSVC++ 2010 |
   | Hostname : xianxianxian |
   | Precision : Single precision (I4R4) |
   | SVN Version: 105897 |
   | Unauthorized use infringes LSTC copyrights |
 Executing with ANSYS license
 Input file: d:\penetr~1\budong.k
 The native file format : 32-bit small endian
 Memory size from default : 20000000
As a new user of ansys, I may have encountered an "Unauthorized use infringes LSTC copyrights" issue. When I modified an environment variable, the issue was not resolved. I don't know what other problem is causing me to not be able to do the calculations properly. Thank you for your help.
