Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Probem with modal Analysis › Reply To: Probem with modal Analysis
April 2, 2024 at 11:55 am
Hi - it sounds so yes - there are some other techniques that are common and appropriate for calculating wet modes of ships (so taking into account the fluid added water effect) using panel methods - we do not have that currently.
One example of such methods can be found hereÂ
https://www.atlantis-press.com/article/22234.pdf
